Hoping some of yo out there can help me.
I'm using my computer to capture video from a VCR so I can covert some of my VHS vids into AVI's and then subsequently into WMV for longer term storage.
I'm using VirtualDub to record the video via my VIVO card and the sound plugs directly into my sound card.
It all works fine except the resultant Avi has problems with lip sync.
Is there anyway to either fix it? or force virtualdub to correct it on the fly when capturing?
Cheers
CC
I would try using the capture software that came with your capture card first. That usually works best.
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 12:31 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 04:47 -
looking for software that will analyse lip movement to sync audio/video
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Jun 2007, 08:05 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 15:53
