    Jul 2007
    This will probably stump everyone!
    I have a small pencam video recorder (eDVR 5-in 1 by ST Labs), which has also been sold under several other brand names (including Verbatim). This mini-cam records video using MJPG compression, but stores the file in an STLabs proprietary file format which uses an .STJ file extension. The camera came with a file conversion utility called eDVR_Create.exe which converts the .STJ file to .AVI format so it can be imported and edited. I also have a similar conversion utility call AVI_Create.exe downloaded directly from STLabs web site.
    The issue is neither of these conversion utilities now work properly on a Windows Vista PC (surprise, surprise!). They will both load the .STJ file and appear to run properly to convert the file, but they both then crash with a "Failed to Create .AVI" error message when the file would normally be written to disk. I'm guessing Vista is missing a key .DLL library file.
    Does anyone know of any other file converter that will import these .STJ files? Or, if a fix or workaround is known that will allow the conversion software I have to run to completion, that would be equally great!
    Anyone?
  2. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    try 'Multi Conversion software. Probably can be found if you goggle.....STJ very difficult file to convert if you don't have all the tools.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
