How would one put the animations of maya into premier pro? Also is there any tutorials to be found on how to use maya?
I wanna sort of learn how to make a small movie like this: http://www.youtube.com/watch?v=fRdqHKRYk1E
Export the Maya render to a video file. Import the video file into Premiere.
Don't use Maya, but it should be able to export image sequence. You can then import image sequence into Premiere Timeline.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
i'm only using maya because the person who made the vid uses it, how else will i make the effects can anyone recommend a better program?
also for maya, how do i render and stuff, i made an animation but this program is slightly difficult to handle. Any place where i can get video tutorials? -
Maya is rather expensive software. If you own it, it comes with a book, and I know for a fact the export process is described in the manual.
i don't even know what export is. My head hurts looking through the manual just to find what I am looking for...
I would also like to know how you impliment the effects from maya, like the balls and beams to the video in the youtube link.
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 06:02 -
Problem with CS4 Premier Pro
By Devilish Me in forum EditingReplies: 4Last Post: 12th Mar 2009, 18:06 -
Exporting HD in Premier Pro
By videopetur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Jan 2009, 15:20 -
Premier Pro 3.0 - titler problem
By The Linguist in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 19:46
