I have a leadtek expert pci tv tuner. It has served me well for several years but I feel it is time to move up to something nicer. What options are out there for under $200 that does NTSC? The leadtek card has noise in the picture. There is bound to be something that will give me a cleaner picture. I like to watch tv on the pc and record to dvd for viewing on my big screen tv. Thanks!
If you don't need high def than a hauppage mpeg card will serve you well. The 250 and 350 are highly rated here. However they will not record into avi mode if that is a factor for you. There are hauppuage cards that will do avi but I don't know which ones for sure.
I use a dvico fusion hdtv capture card that works very well with analog and hdtv.
Check this link for more options:
https://www.videohelp.com/capturecardsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
leadtek dtv1000t digital tv tuner card capture resolution.
By g12345567 in forum DVB / IPTVReplies: 4Last Post: 22nd Jul 2007, 12:56
