I want to burn a divx file (Aprox. 450mb) on to a CD (not a DVD), so that I can play it on my DVD player which says it can play Divx. Do I just burn the CD as a data CD, with the Divx file in it, or should I do something else?
yep just burn as data.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You can also burn (save as data) numerous divx files on a regular dvd blank disc that your player will work with.
What you get onscreen is a list type menu of the filenames you can select to play. It will also automatically start playing the next file when one completes.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 04:50 -
DivX File, How Do I burn To DVD???
By jam90 in forum Video ConversionReplies: 3Last Post: 27th Jan 2008, 15:49 -
how do i burn a divx?
By php111 in forum Newbie / General discussionsReplies: 12Last Post: 6th Aug 2007, 17:56
