I have a couple AVI's that spit out hundreds of errors when trying to encode to DVD with mpeg2enc, but they play fine with VLC. I tried to encode with ffmpeg instead, but it only produced an mpg file (even with elementary streams turned on) which I then can't apply a 3:2 pulldown to. When I demuxed the mpg I got more errors. When I tried to use the 'fix' tool, the resulting AVI looked screwed up like the keyframes were erased. Here is the log for one ....
Code:Last login: Fri Jul 6 17:34:05 on console Welcome to Darwin! /ffmpeg/ffmpegX.app//Contents/Resources/pbpaste | sh d209-121-149-17:~ Joe$ /ffmpeg/ffmpegX.app//Contents/Resources/pbpaste | sh Encoding started on Fri Jul 6 19:19:48 PDT 2007 INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler Input #0, avi, from '/huckabees.avi': Duration: 01:46:38.2, start: 0.000000, bitrate: 1958 kb/s Stream #0.0: Video: mpeg4, 720x304, 23.98 fps Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s Output #0, yuv4mpegpipe, to 'pipe:': Stream #0.0: Video: rawvideo, yuv420p, 480x480, 23.98 fps, q=2-31, 200 kb/s Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding ++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=480x480, frame rate=2997:125 fps)!! error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 90080 error, non monotone timestamps 0 >= 153886 bitrate=20090.5kbits/s error, non monotone timestamps 0 >= 4592151 bitrate=63723.0kbits/s error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4592151 error, non monotone timestamps 0 >= 4610917 error, non monotone timestamps 0 >= 4610917 error, non monotone timestamps 0 >= 4610917 etc ...
Here is the log for the other ...
Code:Last login: Fri Jul 6 19:26:33 on ttyp1 Welcome to Darwin! d209-121-149-17:~ Joe$ /ffmpeg/ffmpegX.app//Contents/Resources/pbpaste | sh Encoding started on Fri Jul 6 19:26:35 PDT 2007 INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler Input #0, avi, from '/Mirror Mask.avi': Duration: 01:40:56.2, start: 0.000000, bitrate: 970 kb/s Stream #0.0: Video: mpeg4, 576x320, 23.98 fps Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s Output #0, yuv4mpegpipe, to 'pipe:': Stream #0.0: Video: rawvideo, yuv420p, 720x480, 23.98 fps, q=2-31, 200 kb/s Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding ++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=2997:125 fps)!! error, non monotone timestamps 0 >= 18766 error, non monotone timestamps 0 >= 18766 error, non monotone timestamps 0 >= 18766 error, non monotone timestamps 0 >= 37533 error, non monotone timestamps 0 >= 37533 error, non monotone timestamps 0 >= 37533 error, non monotone timestamps 0 >= 37533 error, non monotone timestamps 0 >= 56299 error, non monotone timestamps 0 >= 56299 error, non monotone timestamps 0 >= 56299 error, non monotone timestamps 0 >= 56299 error, non monotone timestamps 0 >= 75065 error, non monotone timestamps 0 >= 750659 bitrate=18942.8kbits/s error, non monotone timestamps 0 >= 75065 error, non monotone timestamps 0 >= 75065 error, non monotone timestamps 0 >= 93831 error, non monotone timestamps 0 >= 93831 error, non monotone timestamps 0 >= 93831 error, non monotone timestamps 0 >= 93831 error, non monotone timestamps 0 >= 112598 error, non monotone timestamps 0 >= 112598 error, non monotone timestamps 0 >= 112598 error, non monotone timestamps 0 >= 112598 error, non monotone timestamps 0 >= 131364 error, non monotone timestamps 0 >= 131364 error, non monotone timestamps 0 >= 131364 error, non monotone timestamps 0 >= 131364 bitrate=19337.4kbits/s error, non monotone timestamps 0 >= 150130 error, non monotone timestamps 0 >= 150130 error, non monotone timestamps 0 >= 150130 error, non monotone timestamps 0 >= 150130 error, non monotone timestamps 0 >= 168897 error, non monotone timestamps 0 >= 168897 error, non monotone timestamps 0 >= 168897 error, non monotone timestamps 0 >= 168897 error, non monotone timestamps 0 >= 183910 error, non monotone timestamps 0 >= 183910 error, non monotone timestamps 0 >= 183910 error, non monotone timestamps 0 >= 183910 error, non monotone timestamps 0 >= 191416 bitrate=21037.3kbits/s error, non monotone timestamps 0 >= 198923 error, non monotone timestamps 0 >= 217689 error, non monotone timestamps 0 >= 225196 error, non monotone timestamps 0 >= 232702 bitrate=28413.7kbits/s error, non monotone timestamps 0 >= 240209 error, non monotone timestamps 0 >= 251468 error, non monotone timestamps 0 >= 251468 error, non monotone timestamps 0 >= 262728 error, non monotone timestamps 0 >= 262728 error, non monotone timestamps 0 >= 270235 error, non monotone timestamps 0 >= 281495 bitrate=29970.5kbits/s error, non monotone timestamps 0 >= 281495 error, non monotone timestamps 0 >= 292754 error, non monotone timestamps 0 >= 292754 error, non monotone timestamps 0 >= 304014 error, non monotone timestamps 0 >= 304014 error, non monotone timestamps 0 >= 315274 error, non monotone timestamps 0 >= 315274 error, non monotone timestamps 0 >= 326534 bitrate=30419.3kbits/s error, non monotone timestamps 0 >= 326534 error, non monotone timestamps 0 >= 337793 error, non monotone timestamps 0 >= 337793 error, non monotone timestamps 0 >= 349053 error, non monotone timestamps 0 >= 349053 error, non monotone timestamps 0 >= 360313 error, non monotone timestamps 0 >= 360313 error, non monotone timestamps 0 >= 371573 bitrate=30828.8kbits/s error, non monotone timestamps 0 >= 371573 error, non monotone timestamps 0 >= 382833 error, non monotone timestamps 0 >= 382833 etc ...
FFMpeg Dual Audio MKV/OGM Non Monotone Timestamp
By blazerqb11 in forum Video ConversionReplies: 8Last Post: 25th Jul 2008, 16:36 -
Watching DV video (using WMP etc.) with timestamps?
By Colmino in forum Software PlayingReplies: 2Last Post: 2nd Apr 2008, 17:50 -
convert VOB to WMV with Timestamps
By agostal in forum DVD RippingReplies: 0Last Post: 13th Nov 2007, 16:42 -
Bumping monotone sound
By Ctracks in forum ffmpegX general discussionReplies: 0Last Post: 31st Jul 2007, 10:39 -
Anachronistic or discontinous timestamps in Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2007, 02:41
