Can anyone tell me if Flash Drives are all the same speed? I have two drives and they seem to transfer data at different speeds. May be my imagination.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Most likely it isn't your imagination. Do all hard drives transfer at the same speed? Nope. I would expect that the chipset used in the flash drive to impact performance.
I would even expect that the cheaper flash drives are using slower flash memory to reduce cost.
USB2 interface is only one component of throughput.
Having sadi all that I never thought of benchmarking them. -
To add to that: -- USB2 Full Speed or USB2 High Speed? :P
Personally, I like SanDisk and Memorex flash drives. Had a few other brands like PQI and ended up tossing all of them. -
I'm talking about USB2.0, and is SanDisk any faster?. My drives are both no name brands but they do a good job, except one is slightly faster but hardly worth worrying about.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
USB Flash drive speed varies similar to SD/Compact Flash Modules.
http://www.tomshardware.com/2005/05/20/data_transfer_on_the_run/page10.html
http://www.hothardware.com/articles/USB_Flash_Drive_RoundUp_Corsair_OCZ_and_Kingston/?page=6 -
Thanks, very interesting. The charts show a BIG difference in speeds. I think I'll go for the faster drives from now on.
Experience With Flash Drives --- What Are Best Brands?
By Frank-0-Video in forum ComputerReplies: 5Last Post: 16th Jun 2011, 05:48 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Philips DVP5982 Compatible USB Flash Drives
By Nikephoros in forum DVD & Blu-ray PlayersReplies: 22Last Post: 20th Mar 2009, 00:34 -
USB Flash drives not working anymore
By freebird73717 in forum ComputerReplies: 7Last Post: 7th Jun 2007, 15:28 -
What's the deal with these cheap flash drives?
By ahhaa in forum ComputerReplies: 10Last Post: 8th May 2007, 12:03
