Hi,
I just downloaded Super 1 and tried to convert the *.VOB from the VIDEO_TS folder from a DVD movie (converted from DVDFab) to MPEG4 file. I dropped all the VOB files to the multimedia file and try to convert. I get error. :[
What am I doing wrong?
Here are my settings:
output container: mp4
output video codec: MPEG-4
output audio codec: AAC
internal endoers: ffmpeg and x264 highlighted
VIDEO: NoChange highlighted
25 freame/sec highlighted
1248 bitrate kbps
hi quality/48k audio highlighted
AUDIO: 4410 sampling freq
2 channels
64 kbps
Any suggestion?
I like the tool and read the pdf file but all the jargons seem foreign to me.
Results 1 to 9 of 9
SUPER may not be a great tool for that. You might try AutoGK instead as it may be better for your uses. You are apparently converting a DVD to H264 with AAC audio? That's going to be really slow.
Or if you want easy, try FairUse Wizard. There is a freeware version on the FUW toolpage. They will both encode to Xvid or Divx, though. Or if you really want 264, try MEgui and X264.
And what is the exact text of the error? -
Hello,
1. First you need to join all of your movie.VOBs together into 1 large file before you feed it to an encoder. VOB2MPEG or even simpler VOBMerge will do this, I don't know if it's possible in DVDFab to rip your DVD without "file splitting" but that would work as well.
2. Try this: https://forum.videohelp.com/topic331773.html It is for iPod conversion but it puts out really good quality MPEG-4 movies for any use, select widescreen or fullscreen and drag and drop. -
I'm curious, but why not just use DVDFab? it converts DVD to MPEG4.....you say converted from DVDFab.....and yeah as redwudz suggested fairUse Wizard for Xvid.....
" Who needs Google, my wife knows everything" -
[hanks GMaq,
The VOB2MPG seems to work the best for me even though the audio volume is substandard.
Tquote="GMaq"]Hello,
2. Try this: https://forum.videohelp.com/topic331773.html It is for iPod conversion but it puts out really good quality MPEG-4 movies for any use, select widescreen or fullscreen and drag and drop.[/quote] -
Originally Posted by t0nee1
Well. I don't think it is free. LOL. -
DVDFab HD Decrypter = Free
DVDFab Platinum = Not free.
Just "DVDFab" could refer to either.
Platinum uses libavcodec (x264) for encoding anyway. -
AFAIK, DVDFAb = DVDFab Gold/Platinum, not HD Decrypter Soo OP should have stated proper description..I'm no mind reader and I doubt anyone else is...JMO..... BTW love FairUse Wizard = the free one.....
Converting .VOB files to MPEG4 with Streamclip and MPEG2 Playback Component
By MLK3329 in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 14:51 -
question on vob files
By rtr720 in forum Authoring (DVD)Replies: 12Last Post: 17th Jan 2010, 12:00 -
Question about editing VOB files
By C0SM0 in forum EditingReplies: 19Last Post: 26th Feb 2008, 19:53 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05 -
DVD chaptered VOB's to MPEG4?
By procooper in forum DVD RippingReplies: 1Last Post: 24th Nov 2007, 18:08
