I am trying to find a capture card or any product related to it. I am trying to find something that to get footage from my TV screen and I can have it uploaded to my computer. Can somebody help me out? Thanks for any responses on what I should buy.
Results 1 to 12 of 12
Originally Posted by jonathan3566
Originally Posted by edDV
Well, what is your budget? Expect to pay $150 for something pretty decent in a PCI card to fit inside your PC, and can record Hi definition HD video. You won't need your TV - the Computer can directly record over the air TV and basic unencrypted cable
Capture cards come as non-encoding and encoding. Non-encoding cards need a faster computer and more tech involvement. Guides exist on this site for required software and technique.
Most prefer a capture card that encodes to DV, MPeg2 or MPeg4 on the card. A typical example is the Hauppauge PVR-250 (or the newer PVR-150 or 500) that encode to MPeg2.
http://www.hauppauge.com/pages/prods.html
http://www.hauppauge.com/pages/prods_pvr.html -
http://www.hauppauge.com/pages/products/data_pvrusb2.html
With this can I just connect it to my TV and record whatever is on the screen? If so, to upload it to my computer I just plug it into my USB port. Am I correct? -
Yes it will record what comes out of the TV output to an MPeg2 file under control of WinTV 2000 software.
Before spending the money, first connect the TV output to another TV or VCR to verify the signal you want is there. -
What Product to buy to view DIGITAL cable TV on my PC?
By trighap in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2011, 16:48 -
Capture Card Unigraf UFG-03. Where is I can buy it?
By Andrey97 in forum ComputerReplies: 3Last Post: 3rd Feb 2011, 11:51 -
I bought the product and successfully paid using cdt card. Received
By dough_roller in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Jul 2010, 14:46 -
I'm having a problem deciding what Capture Card to buy
By Mufc in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 09:10 -
Is it possible to capture like this? (Videogame related)
By fathertadpole in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2010, 10:47
