Hi I need to capture some audio from my Cable Box into my DVD Recorder but I want to have the best audio quality possible. Can anyone recommend me some quality audio RCA cables to buy?
thanks
Avoid the very cheap ones and the most expensive, such as Monster or similar. After all, it is just a piece of wire.
For specific brands, I go for Belden or other major cable manufacturers. But even with the cheap cables there's very little, if any difference, in signal quality unless you are making long runs, over 4 - 5 feet. Avoid the 'hype' of some cable sellers. What you want is a flexible cable, with good quality insulation and good connectors. You can find both with inexpensive cables. A good quality single three foot RCA cable should be less than $10US. -
3ft?
You seem to be selecting for beauty. Most any cable will work for 3 feet (1 meter). What are you connecting? -
I don't agree with the "wire is wire" philosophy. I know I can hear differences in clarity, bass, smoothness, etc. between various cables.
"the best audio quality possible" usually equals a high price.
I've been using Signal Cable's Silver Resolution which are excellent but most people would balk at the steep price. They have other less expensive cables which are almost as good. And they have a 30-day return policy and lots of positive reviews.
http://www.signalcable.com/analog_interconnects.html -
I'll agree to disagree. If you want higher quality use line level low impedance 600 ohm balanced XLR connections and forget using Hi Z unbalanced with RCA connectors. Spending a lot on high impedance RCA cables is like putting a 12 coat gold paint job on a Geo Metro. Consumer audio is consumer audio.Originally Posted by piano632
A quick ref.
http://www.videomaker.com/article/1766/ -
Hi thanks for the replies, im connecting my Digital Cable TV Box to my DVD Recorder JVC but the recorder only has RCA Audio input.
This cable has all the premium features you might need and may be overkill for 3 ft.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=479879&CatId=449
Special features like double shielding come into play for long (> ~12 ft) runs. For very long runs, consider stepdown transformers to 600 ohm.
Laptop to Tv no audio with RCA cable
By syboz in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2012, 21:13 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 17:33 -
Speaker wire to RCA? cable needed...
By flamy in forum AudioReplies: 12Last Post: 24th Dec 2010, 13:05 -
I cant get Svideo to RCA cable to work on my PC to TV.
By awaisuk in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2009, 14:49 -
S-video cable..better to use than RCA Jack audio, video cables?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2009, 09:38
