i have a vob file which has a multitrack audio (dd5.1 and dd2.0)
when i put it in the author it only reconiizes the 5.1 track and the other one dissapears.
how can i make it keep both audio tracks?
thansk in advance to who can help.
Results 1 to 9 of 9
You can't. TDA 1.6 only supports 1-audio track. You need to use another authoring app to do this. I think the latest version TDA support 2-audio tracks.
EDIT: strike that ... I went the TDA website and 3.0 supports 2 subtitles but I didn't see anything about it supporting more that 1 audio track.
And, TDA 2.0 only supports one ... -
I use TDA 1.6, but a quick look at the DVDlab site shows that DVDlab studio supports 2 audio steams. They offer a free 30-day trial. I'm not sure it that's a fully functional version or a limited trial version.
TDA3 supports both 2 subtitle tracks and 2 audio tracks, both are switchable, and many of the included templates offer automatic creation of a "Setup" menu page that lets you select your audio and subtitle tracks. Works very well.
Author your DVD with TDA, then replace the VTS_0x_x.VOB TDA created (only the VTS that contain that movie) with the matching 2 audio originals.
DO NOT REPLACE the VTS_0x_0.VOB, that one contains the nice menu you spent so much time making with TDA.
i.e. If your original VOBs were VTS_04_0.VOB-VTS_04_5.VOB and TDA made VTS_02_0.VOB-VTS_02_5.VOB, then you would rename VTS_04_1.VOB to VTS_02_1.VOB... But not replace VTS_02_0.VOB and the IFO and BUP files.
Then use Ifoedit to re-align the VIDEO_TS.IFO and VTS_02_0.IFO with the VOB using the "Menu Extras" and "Get VTS sectors" buttons. Check this for more:
https://forum.videohelp.com/topic259346.html
Make copies of all the files before you start. -
I have TSUNAMI-MPEG DVD Author PRO 2.1.5.77 & TMPGEnc DVD Author 3 with DivX Authoring & they both supprt 2 audio channels/tracks.Originally Posted by nwa
I believe they went to two audio tracks the first version of TDA 2.
But i use DLP pro as it supports many audio tracks as well as DTS.
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 02:24 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58
