I have a question...I have a burner in my laptop ( i think it is a toshiba) and I have an external burner. I am using tda 3 and when I select the external burner it gives me more choices for burn speed like 2.4x 4x 6x 8x and 16x however when I select my laptop burner i only get 2 choices 4x and 8x I understand why it wont give me 16x becuase it cant burn faster than 8x but why wont it give me anything lower than 4x....I am new to dvd burning so could someone explain to me why some drives have more speed choices than others?
	Burners are controlled by firmware, which contains the write strategy for various discs, generally based on media ID. The manufacturer has decided that a certain make of disc is best burned at certain speeds by this particular burner. The burning software gets the speeds from the burner's firmware. Sometimes updating the firmware to newer versions, or unofficial versions can add new strategies and open up new speeds.
 Why would you want to burn at 2.4 x on faster discs anyway ? If you discs are so poor that you have to burn that slowly to get results, you need to buy better discs. Otherwise, don't worry about missing the slower speeds when working with faster discs.Read my blog here.
	I spoke with hp (the manufacturer of my computer) they said they have not recieved a firmware update for the gsa-4084 from lg they said they will be getting one soon...I couldnt find the firmware for it..or any other laptop dvd drives for that matter ..on lg's website...only the gsa's for desktops ...am I loooking in the wrong place? does anyone out there know if theres a firmware update for the gsa-4084 out there or is KQ09 the latest??? let me know
	I forgot to mention i am burning a dl dvd and the choices are 2.x and 4x i tried it at 4x and i have kind of an old dvd player so it skipped...so i tried it at 2.4x on another dvd burner and it played fine...anyway i think kq09 is already the latest firmware for my dvd writer
  SubRip doesn't give me option to save srtBy diamondback in forum SubtitleReplies: 7Last Post: 13th Jun 2010, 09:59
  dvd fab wont recognize target burner driveBy lauraji in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2009, 01:34
  PC not give out any video?By mvp in forum ComputerReplies: 10Last Post: 3rd Mar 2008, 21:58
  Dvd Burner Wont CopyBy Catman209 in forum DVD & Blu-ray WritersReplies: 12Last Post: 16th Dec 2007, 00:35
  What CD/DVD Burner will give me the best results for my Gateway GT5056By uncleB in forum DVD & Blu-ray WritersReplies: 17Last Post: 25th Oct 2007, 09:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
