Build quality not brilliant but for the price (£99) you get amazing features.
It seems to play all formats including DVD-R
Burned a mpeg2(SVCD) and mpeg2(DVD) files on a CD-R. A 'Explorer' type window comes up and you just select the file and it will play it! (I suppose this is miniDVD)
How do I create the miniDVD to autoplay..i.e. is there a certain file structure or is there any software that allows (mini)DVDs to be burned on CD-Rs??
No its not, miniDVD is simply DVD Format burned onto a CDR/RW, DVD format is udf/iso 9660 brudge mode.
Can't Caputre MiniDVDs.
By menash07 in forum Capturing and VCRReplies: 1Last Post: 26th Jun 2010, 18:50 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 13:29
