  1. Member wulf109's Avatar
    Jul 2002
    Some ifo files contain more cells than chapters. Is there a program that would allow editing out the additional cells so that cell and chapter count is the same. Of course without compramising playback.
  2. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    It's normal, what do you want it for? You can edit or delete commands (if any) assigned to individual cells if you need to correct navigation (DVDRemake).
    Aug 2005
    AKL, NZ
    Is your DVD dual layer? Cell markers also set up the layer break. Angle changes etc can be aligned
    to cell markers. This is all determined at time of authoring. Unless the cell is configured as a
    layer break you will not see anything on play back. If there are cell commands recorded in the IFO
    for that PGC the disc may instruct your player to navigate back to menus or jump to another location.
    Demux your vobs and reauthor your movie allows you to remove them fully.
    Aug 2004
    pgcedit can remove cells without re-authoring.
  5. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    This removes video content (if you don't mean joining cells ).
    Aug 2004
    You're right...the remove cells function won't make that part of the VOB playable. I see it can output the celltimes of the chapters only, but then you have to demux --> remux --> replace...etc. I didn't see a join cell function in my version of pgcedit.
