  1. I am trying to Convert a SVCD to a VCD by follwing the instructions at http://www.vcdhelp.com/mpeg2tovcd.htm i get the first part done no problem, but then when i go to open the .d2v file in TMPGEnc it says the file is not supported, I installed the plugin VFAPI plug-in for TMPGEnc project file (344KB) as directed, but still no luck, any suggestions?
  2. :cry:
    I'm getting the same problem the audio file will go into TMPG but when i try and insert the .d2v file i got from DVD2avi it say the file is not supported. I uninstall the plug-in and deleted TMPG then re downloaded both and tried reinstalling again. I have a Win2000, P4, 1.4ghz 512mb of ram so my system should not be the problem any other guides or suggestions. Oh and changing the header is a problem also TMPG crashs and I do mean crashes when ever i try and load the mpg file for a simple multiplex. Thanks
