I have some AVI files I need to stream for a demo coming up. They need to go out as unicast & the AVI files are MJPEG. Multicast will not work because they need to stay MJPEG so the system receiving the stream can decode properly (MPEG is not supported). I want it to play over and over and over until I stop the stream manually.
I am in search of Linux utilities to be able to do this. Any suggestions??
Hi,
What is the bitrate of these files? MJPEG is usually pretty high bitrate to get any quality which will give you headaches to stream them. VLC is supposed to be able to stream in most cases people use it to transcode on the fly, (K)MPlayer will also stream but i have no personal experience with how to do it. I think bandwidth will be your biggest hurdle to overcome.
How to stream/broadcast live TV using Star Media Center
By Baldrick in forum User guidesReplies: 17Last Post: 27th Jun 2015, 12:49 -
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27 -
Improve comprimibility in SD broadcast stream
By elmuz in forum DVB / IPTVReplies: 23Last Post: 8th Apr 2011, 13:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
Replace audio stream in a DV AVI file
By dzoge in forum EditingReplies: 3Last Post: 6th Jun 2007, 19:57
