I'm trying to convert some WMV files to AVI, but for some reason the audio portion of the file shows as a slightly different length than the video portion--usually a couple seconds shorter. The WMV files play fine anyway for some reason, but after conversion the audio slowly drifts out of sync over time.
I can demux and convert the audio format just fine, but what I need is a (free) tool that will make very small adjustments to the audio speed so it matches the length of the video. Audacity only adjusts in percentages, so when I'm trying to add two seconds to 45 minutes, it isn't fine enough.
Is there another tool that would allow me to give a specific desired length, either in time or frames?
Thanks in advance for any help you can give.
Best,
Calidore
Results 1 to 1 of 1
How to fix audio sync issue in a wmv file
By pjbarbour in forum AudioReplies: 11Last Post: 20th Nov 2012, 14:29 -
How To Fix Audio Sync Problems 102
By gcsnelgar in forum User guidesReplies: 32Last Post: 25th Feb 2011, 20:04 -
avi file out of sync, still no fix.
By kiko2k2kris in forum Video Streaming DownloadingReplies: 9Last Post: 6th Dec 2009, 13:00 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 21:28 -
How To Fix Audio Sync Problems 101
By gcsnelgar in forum User guidesReplies: 2Last Post: 24th Jul 2007, 12:11
