Well, it must be something wrong with my PC or something.
I have an Intel D945 Dual Processor @3.4GHz - 1GBRAM - >free HDD ~200GB,
video ASUS X1600PRO PCIe 256MB/128b and all the codecs installed (ACE).
- My systme is updated to the latest (WinXP PRO SP2 - genuine)
I have some HDTV clips from my friend - but nothing will play them smootly. Video just freezes, or runs in slow motion and things like that.
I have tried with:
InterVideo WinDVD 8
BSPlayer PRO
WMP 11
VLC
What is wrong ?
(user ?)
Results 1 to 12 of 12
To cut, or not to cut ... who is the splitter ?
Your system should play MPeg2, divx-hd and wmv-hd but will struggle with h.264 and vc-1.
an upgraded video card will greatly improve this. for ati nothng less than x1900 nvidia has two option 86XX 88XX 86xx series is gonna be much cheaper but is what most HTPC users are using.. the 88XX is gonna b great for gaming and other stuff for a bit longer.Originally Posted by edDV
Full hardware based h.264/vc-1 decoding is still out of reach. They are balancing hardware assist with CPU horsepower and driver tweaks to get to full playback. I'm watching all this with interest but have my $ invested elseware until a full hardware playback is supported.
I'm also looking for hardware assist or full hardware h.264/vc-1 avc encoding. -
Well, it should but it does not play the files correctly.Originally Posted by edDV
The video plays slow motion and the audio plays normal. So it is at least annoying.
I have seen that the files are @59.9fps.
Someone please can give me an explanation of what i'm doing wrong?
I just want to look at some videos, is that too much to ask from my PC
To cut, or not to cut ... who is the splitter ? -
59.94fps indicates 720p broadcast.Originally Posted by Soreen
You aren't doing anything wrong. If you want these to work you need to participate in the beta testing.
Tell us more about the file you are trying to play. What is it? -
Jennifer Lopez - 2007 Oscars [HDTV 720P]
This is the file causing troubles. I have more ... but you will get the point i think
And btw - thank you for helping me!
here u can download the file:
http://rapidshare.com/files/18325757/JLopez2007OscarsHDTV720P.aviTo cut, or not to cut ... who is the splitter ? -
even mpg will be choppy with that video card. I too am playing around in this area. you can try to close/stop all running applications that should help.. if you have access to another video card giv it a shot as a test. my money says taht it will play fine with a card close to the ones i posted. also make sure all the codecs are installed and working correctly.. using VLC will eliminate that issue. but still a good idea. that clip you are trying to play is a divx/xvid file anyway not mpg and those are up there in cpu/video requirements too. look for proper ac3 filter and divx filters codecs
EDIT: i just had a thought microsoft has a site for HD clips in both 720p and 1080p.
http://www.microsoft.com/windows/windowsmedia/musicandvideo/hdvideo/contentshowcase.aspx
try a few of these. if they work then you might be able to narrow the problem more -
Well , for what its worth , my dell lat d610 laptop with only 32mb ati , 256mb ram , was not quite able to keep up with that clip , or one I got in 720p from ms site .
The clip link , kept falling behind video ... kept playing audio , and just jumped to the point in the video .
720p wmv from ms , ran at 22.6fps average .
Not bad for something that runs at 1200mhz .
Tested via windows media player 9 , koolplaya , nero showtime .
You really do have something wrong in the setup ... first given ... get rid of that ace codec pack to start with ... then work up from that .
And dont upgrade the video card ... consider checking for an updated drivers package for it instead . -
That did the trick - I have upgraded to the latest the DivX player too - and then i just started the configuration utility and stopped the post processing. (I write this cause there may be others experiencing the same problem)Originally Posted by jagabo
Thank You very much!
respect,To cut, or not to cut ... who is the splitter ?
best way to play movies on hdtv?
By zadam123 in forum Newbie / General discussionsReplies: 8Last Post: 8th Oct 2011, 22:01 -
How to play a HDV disc on my HDTV?
By rcguy1 in forum Authoring (DVD)Replies: 17Last Post: 20th Jan 2008, 22:46 -
play HD DivX from PC on HDTV
By proctor in forum DVB / IPTVReplies: 14Last Post: 6th Nov 2007, 12:23 -
How can I play 4 clips on SONY VEGAS 7.0?
By qazwsx16 in forum EditingReplies: 2Last Post: 28th May 2007, 19:28 -
Can't play HDTV wmv movie on my PC
By mikee55 in forum Video ConversionReplies: 1Last Post: 10th May 2007, 11:44
