I tried backing up a legitimate copy of Shining Through using 1Click DVD Copy Pro v2.5.0.9 & DVD43 v3.9.0 but for some unknown reason I have no sound when playing the burnt DVD-R in my DVD player (Pioneer DV270) I have no problem playing the original DVD though.
Does anybody have a suggestion as to what went wrong?
	Pedro
	did you anable 1click's CPRx, if you didn't you should, 1click needs CPRx to work with dvd43. Now you can buy anydvd & 40 and you should have no more problems, or you can ripp the movie to your hard drive with fabdecrypter(free)first, and then use iclick to compress it. I don't trust dvd43, i would go with fabdecrypter/1click.
  Winx dvd copy proBy jajabong in forum Authoring (DVD)Replies: 5Last Post: 29th Oct 2011, 00:37
  DVD43 64-bit?By dvdcollector in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2011, 00:31
  Free DVD encrypter for copying DVD's? DVD43 won't work for meBy marcias_70 in forum DVD RippingReplies: 1Last Post: 2nd Feb 2009, 04:09
  DVD43 4.0.0 with VLC 0.8.6dBy pwhyles in forum Software PlayingReplies: 0Last Post: 23rd Feb 2008, 07:33
  Any 1Click Blu-ray / HD-DVD method to extract selected Video/Audio streams?By jmone in forum DVD RippingReplies: 3Last Post: 2nd Jan 2008, 11:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
