Hi,
I've converted a DVD to DivX using FairUse Wizard, but the audio volume is too low.
Is there a way to adjust the volume while or after conversion?
Marco
I've also read that AC3 Filter could be used while encoding, is it right?
Which settings should I change before conversion?
Marco -
I've tried both MP3 (at 192 Kb/s) and AC3, but the results are the same: volume too low.
May be I'm able to raise the volume during playback with AC3 Filter, but I'd prefer a better way to encode in the audio stream of the DivX movie. -
Ok, it doesn't run mp3gain and the azid settings are somewhat fixed. Is this a common problem for people? If so anyone got any azid settings that they recommend? From recollection when I tested I didn't have a problem.
Run the output AVI through one of the AVI_GAIN scripts. That'll be very easy.
https://forum.videohelp.com/topic314909.html
Not to step on your train of thought, celtic_druid . You da man.
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 18:34 -
Fairuse wizard
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2010, 12:37 -
Fairuse Wizard
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 05:38 -
FairUse Wizard error
By dudeman316 in forum DVD RippingReplies: 3Last Post: 21st Jul 2009, 12:58 -
FairUse Wizard Audio Volume too low
By herzeleid in forum DVD RippingReplies: 1Last Post: 11th Oct 2008, 19:05
