    Oct 2006
    Australia
    Hi,
    I have recently purchased the USB Mpeg4 Grabber GA-VD207 and it seems to be a great USB device to make Mpeg4 DivX vids!
    But there is something i really need help with!
    I can record a video file but the software that comes with it does not appear to have an 'Timed Recording' Option. For example, i can start the recording, and i want it to stop 2 hours later automatically.
    Is there any software that i can use with the USB Mpeg4 Grabber to set the recording length or even a scheduled recording time?
    Here is a direct link to the Taiwanese manufacturer, but my requestes for email support has gone un-answered.
    GLOpro
    Feb 2004
    Australia
    The device might be an issue , but you could try the following :
    Media Portal
    GB-PVR
    Got All Media
    SesamTV Media Center , really works well on lower ended systems .
    You may even be able to write a script in autoit , which will run the task when required via the program that originally came with it .
    Oct 2006
    Australia
    Thanks Bjs,
    I have GB-PVR on my HTPC and previously used it with my PVR350. It did a reasonably good job back then for scheduled recordings.
    I will give it a go again with the Mpeg4 Grabber.
    Thanks for the tip!
    Plenty of Foxtel content i want to back up off the Foxtel-IQ
    GLOpro
