For encoding a widescreen dvd (in VCD format), what would be the correct display ratio? 4:3 or 16:9 or 1:1 vga? What would be correct for a full screen dvd? Also, do I "keep aspect ratio2" ?
How bout' I eat yo cornbread?
In tmpgenc under advance tab set source aspect ratio to 16:9 525 line (NTSC) or (PAL), video arrange method full screen (Keep aspect ratio)and aspect ratio on video tab to 4:3 if you have a 4:3 TV
I am not too sure about this. I have seen many (actually most of them) DVDs, that came with a source aspect ratio 16:9 generetic. Before you set source aspect ratio 16:9 525 line NTSC, make sure it is correct.
You can use Bitrate Viewer to check the source. -
Very good question, Antknee24, but I'm looking after this too. So please anybody , what about the keep aspect ratio2 compare to keep aspect ratioOriginally Posted by Antknee24
VHS-DVD Screen Ratio Problem
By Ozzyjim in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jan 2011, 22:27 -
Can't get aspect ratio 16:9 to fill the screen when play DVD movies.
By Herbert Smith in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Sep 2010, 06:37 -
Advice needed on issue with AVI screen ratio
By Ric76 in forum EditingReplies: 4Last Post: 10th Aug 2010, 06:30 -
Split screen, keep aspect ratio and use half of 2 different videos ?
By boulder in forum EditingReplies: 10Last Post: 10th Nov 2009, 11:30 -
Screen Ratio
By green_blade in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th May 2007, 07:45
