Whats the difference between a mpeg and a movie file? Will there be a issue when I try to record both onto a dvd? The files are music videos and I will be making a menu for them also. Thanks.
A movie file is just a generic term for all video files (as far as I'm concerned). An mpeg is one type of movie file; others include avi, wmv, vob, etc. To have an mpeg play on a dvd player, it has to have the ability to play them in the first place. Check the player's manual. Otherwise, to get the mpeg to play on a dvd, the mpeg file needs to be "authored" into files recognised by dvd players ie. an audio_TS folder and a video_TS folder. You need software that can do this like Nero, Womble Video Wizard, DVD Author Pro, etc. Once these two folders are created, they are then burned onto a disc. Some of the authoring programs have this feature as part of the process, some don't so you need a burning program to get it to the disc. When you look at a dvd file structure, you will find the two folders listed. Althought the audio_TS folder is empty, it is required, so don't delete it. Hope this helps.
Converting bluray movie files to low size files
By AndreL in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 01:06 -
Very basic question...... how can I merge mpeg files and make a movie
By True Colors in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2009, 16:45 -
GUI for dvdauthor, movie from 2 MPEG files instead of joining them together
By Steve Walsh in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2008, 09:13 -
Ulead Movie Factory Issue / Mpeg files
By DVDdummy in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2007, 22:57
