I apologize in advance if this is a dumb question, but as a newbie, I have been pretty successful converting .vob files to .avi DivX or .dv files for use in iDVD. However, I have had issues with several DVD's that I recently burned, edited with iMovie, and then burned to iDVD. I converted the files to .dv from .vob (.avi DiVX was giving me problems). The .dv files were crystal clear when played on QuickTime, but after I burned the DVD, the picture would "shake" when there was a lot of movement or action on the screen - making the picture shaky/blurry throughout the movie. Is there anyway I can fix this by converting the .dv file to another format (I tried a .mov file but this was still shaky) or changing some other video parameter?
Thanks in advance!
This sounds like an interlacing field dominance issue. There are some good articles about this on Apple's support site. Here's a good one to start with: http://docs.info.apple.com/article.html?artnum=58634
If you use Toast 7 or 8 instead of iDVD it has a custom encoder setting where you can specify the field order. -
Thanks. Is there a way to deal with the interlacing issue other than Final Cut Pro?
for iMovie:
JES Deinterlacer"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
try this one, SPAM ,iv got same problem with u these days, hoping it do help to ur in converting avi DivX to DVD ,maybe other formats u can have a try,last time buddy pattrick wanna convert ,then serching in google, finally found this sofrware ,but its shareware. anyways u can download it ,as its free downloading.good luck.
MPEGStreamClip (free-donation-ware)
at http://www.squared5.com/
would also be an option.
file converted from vob to mpg does not play on windows need assistance
By idealady in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 7th May 2010, 12:43 -
Converted VOB to MPEG-4, Sluggish Playback
By linnium in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2010, 01:04 -
decrypted, converted .vob to .mpg but have no menus
By chgoguy in forum Video ConversionReplies: 6Last Post: 8th Aug 2009, 17:03 -
Very Strange problem with a Vob file
By nerys in forum DVD RippingReplies: 7Last Post: 11th Nov 2008, 17:33 -
VOB file size problem
By mb1512 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2008, 16:58
