Is there any way to get rid of this kind of interference in the tape? The vertical bars remain fixed throughout the recording. I believe it was recorded this way over-the-air. Is there a Vegas filter or overlay I can use to reduce the brightness of them and blend them into the rest of the frame?
I think thats called "ghosting". I'm not sure if there is a fool proof way to remove it. Do a forum search for ghosting and you might find some possible solutions. But the reencoding time might not make it worth your while to do it. Good luck.
Programs to Remove/Suppress ugly WARNING screen in this W.C. Fields classic
By MISS CHIEVOUS in forum EditingReplies: 13Last Post: 28th Jun 2010, 17:03 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 06:57 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 8th Oct 2008, 00:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29 -
PowerDVD 8 HDDVD - Vertical black bar
By hungledink in forum ComputerReplies: 0Last Post: 6th Jul 2008, 13:50
