I have subtitles in polish,but they are being shown in western font,how can i change that?(.srt,.txt files)When i switch windows language to polish its still western font...
It is not related with windows language.
Depends which player you use, but usually you have to change the font within your player Options>Preferencies>Subtitle>Font.
Maybe font signed as Eastern Europe would work. -
well,i had to do it in VobSub, DirectVobSub/ configure/main/text settings/eastern eauropean and it works in TMPGEncDVDAuthor,i get EE font there but when i play with vlc its western again,the first one was my bigger concern so im fine for now,i looked in vlc but i didnt c font settings there(i mean font charset )fine for now but if somebody have some ideas how to make it all work...please speak now..thx
If your goal are subtitles, change the player.
KMPlayer has the best subtitle support - I use it all the time and this is why:
https://forum.videohelp.com/topic311996.html?highlight=display%20subtitles
Why would subtitle font change in conversion?
By Djard in forum SubtitleReplies: 6Last Post: 25th Apr 2012, 19:07 -
How can i change font subs at KMPlayer?
By eliqush in forum Software PlayingReplies: 1Last Post: 12th May 2010, 17:44 -
Font Style for subs in VirtualDub
By paranoyd in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2008, 07:46 -
Missing subs, size & font can't be changed
By Jacke in forum ffmpegX general discussionReplies: 2Last Post: 17th Aug 2007, 13:04 -
VobSub change font
By Digiface in forum SubtitleReplies: 3Last Post: 3rd Jun 2007, 16:21
