I'm wondering if this bgsvcgen process that I found running was installed with it, I saw a thread here that indicated it might be. Upon Googling the process I found that it could also be malware that disguised itself, even though NOD32 and Spysweeper don't find anything wrong with it.
So, if you have TMPGEnc installed, can you check to see if that process is also installed somewhere?
what tmpgenc might that be? Plus, Xpress Or DVD Author and what version? For example going to this directory on this computer " C:\WINDOWS\system32" shows "B's Recorder GOLD Service Library" after right clicking the file in question, then picking properties.
This is of course with show system files, show extensions, and show Hidden files set in Tools, Folder option, view.
Since mine shows a legitimate company mine should be good.
You need to check yours, it could have been replaced by a virus. Most likely not, however ............. Only you can tell for sure.
Since B's gold is burning software you could just change the extension and see what happens. -
It's DVD Author 3. The file shows the same thing that yours does, and I noticed that it was created one minute after the TMPGEnc was, so it's likely that it got installed along with it.
I guess I could try uninstalling it since I probably won't use it because it takes so long, and then I could see if the file goes along with it. -
bgsvcgen.exe is a B's Recorder GOLD Service Library from B.H.A Corporation belonging to B's Recorder
once the process is reviewed. If you have any information to contribute, you can send it to pl[at]Uniblue[dot]com. It is highly recommended to Run a Free Performance Scan to automatically optimize memory, CPU and Internet settings.
http://www.click2finding.com/click2.aspx?pr=Computers/Hardware/FAQs,_Help,_and_Tutorials/
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
The same OS installed on two disks
By Jomapil in forum ComputerReplies: 29Last Post: 4th Jun 2009, 15:35 -
No Audio output installed
By ray316 in forum ComputerReplies: 1Last Post: 12th Mar 2009, 16:53 -
Just installed and failed
By cantthinkofanickname in forum Newbie / General discussionsReplies: 12Last Post: 21st May 2008, 12:20 -
Why do programs need to be installed?
By Rudyard in forum ComputerReplies: 18Last Post: 18th Jun 2007, 09:00
