Hi, i have a couple of avi files that i would like to burn onto dvd but the frame rate is only 23kbps instead of the normal 25kbps for PAL.
Whenever i burn them to dvd it always seem to skip really bad.
i was wondering if there was a way of making the files look better and not so skippy as i think convertxtodvd is just replicating the previous frame.
thanks
Convert to MPEG 2 at the original frame rate with DVD compatible settings. Then use DGPulldown to add pulldown flags. Search the guides for DGPulldown.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Jittery movement on encoded file (Bitrate setting question)
By cb678 in forum ffmpegX general discussionReplies: 4Last Post: 5th Nov 2011, 15:30 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06 -
Divx (avi container) issues, jittery playback
By adam1972 in forum Blu-ray RippingReplies: 1Last Post: 19th Jun 2008, 19:46 -
Convert avi to Dvd and Burn. Jittery video!
By Ragebflame in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 18:06
