Any help on following - getting - Windows host process Rundll32 has stopped working
after loading svcd2dvd 2.5
Results 1 to 18 of 18
Is this the latest 2.5.2800?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
After acknowledging the error are you able to continue with the program?
Dwight
- Herm Albright
CAn you post a image of the error? At what point does it happen?
i have installed and registered but when i click on to open program the box appears - windows says caused by This problem was caused by lmpgspl.ax. lmpgspl.ax was created by Ligos Corporation.
lmpgspl.ax is a codec. A codec is software that is used to compress or decompress a digital media file, such as a song or video. Media players and other programs use codecs to play and create digital media files.
Troubleshooting
To try to solve this problem, follow these steps. Each of the steps might solve your problem. If following a step doesn't fix your problem, then go on to the next step.
Disable thumbnail view in Windows Explorer
Open Folder Options by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
Click the View tab, and then select the Always show icons, never thumbnails check box.
Click Apply, and then click OK.
Uninstall the program that caused the problem
If this problem occurred after you installed a new program, the problem might be caused by that program. If you know which program you just installed, you can uninstall it.
How do I uninstall a program in Windows Vista?
Click to open Programs and Features.
Select a program, and then click Uninstall. Some programs include the option to change or repair the program in addition to uninstalling it, but many only offer the option to uninstall. To change a program, click Change or Repair. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Unregister the codec from your computer
If you don't know which program is causing this problem, you can remove lmpgspl.ax from the list of installed codecs by unregistering it.
Note: Disabling lmpgspl.ax will cause any programs that depend on the codec to stop working or lose functionality.
Click the Start button, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
From the command prompt, type regsvr32 /u lmpgspl.ax, and then press ENTER. The codec is now unregistered.
If these troubleshooting steps do not solve the problem and you continue to receive problem reports, please consider filling out the survey on the right of this solution page. To help us continue to investigate this error, include the names of the add-ons that are currently enabled in Internet Explorer in the comments area of the survey. -
Dwight
- Herm Albright
Sorry Jikchung this is a bit deep for me - i cannot enter the program - but have not a clue how do do what you ask sorry
Do you think its to do with .net framework 2.0 have downloaded it and now getting - error creating process - c:\users\jp\appdatazlocalztempzixp000.tmp\install, exe\
reason c:\windows\system32\advpack.dll ??? -
OK, I was thinking it may be a codec error (ligos is a codec). If the splash screen plays, then it's probably not that. Are you running the program as administrator?
https://forum.videohelp.com/topic324278.html#1672927
It seems you may have some other things going on, we'll have to let ChrissyBoy weigh in on this.Dwight
- Herm Albright
Any helps would be appreciated as got a number of divx waiting for transfer to dvd -
As per your post - have you tried "regsvr32 /u lmpgspl.ax"?
sorry ChrissyBoy but I'm a novice at this so I have no idea what to do about your last - can you please guide me step by step if possible thanks
OK, on XP (should be similar on Vista) click "Start", then "Run", it should open a text box. Then copy and paste or type the following into the text box (without the quotes):
This will unregister the codec that appears to be causing your problem.Dwight
- Herm Albright
one suggestion - ditch this outdated tripe and go for convertx2dvd
:P :P :P :P -
@nigeltheparrot- Ignore aliali, the poster only pops in from time to time to start trouble as search will show. Here is the posters true opinion of the program:
aliali loves the product but has to do some trolling when on the rag :P even tried to spread a spyware rumor once and was caught doing that.aliali
Member
Posted: Jun 03, 2006 18:32
The easiest thing to use for putting multiple avi's onto a dvd is
SVCD2DVD which has it's own forum on this site if you look, a
great piece of kit and as I say easy to use.
Your problem is apparently with an improperly registered codec in Vista, SVCD2DVD only shows a symptom, it isn't the source of the error.Dwight
- Herm Albright
have reverted back to xp - many thanks for all your helps - sorry to have caused you all problems all the best
SVCD2DVD + Vista
By davezim in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2009, 02:02 -
SVCD2DVD 2.5.5030 Not Working with Vista SP2
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th May 2009, 13:33 -
svcd2dvd not loading aftere service pack 1 vista 64bit
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Apr 2008, 05:23 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 10:35 -
svcd2dvd / vista registration issue
By simonlee in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jun 2007, 15:54
