Since Ifoedit website is not active anymore, I just can't remember how to remove menu's music from DVD![]()
I have a music DVD which is audience taped and the level of music in menu section is much louder than it is during the concert. It gets very annoying if you'd like to change the song via menu and you've already adjusted the volume along the concert music. Then you move back to menu and OUCH! It's so loudTherefore I'd like to remove menu's music completely.
And as always, many thanks in advance!
I can only tell how to do it in DVDRemake: select menu PGC, open 'audio tracks' tab, right-click on audio track line and select 'disable track'. Output modified menu/ifo/bup files and replace old ones (backup to be sure).
DVD Reauthoring - Removing a menu
By xDarKnighTx in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2010, 00:32 -
Removing the subtitle menu from a NORDIC dvd
By tooonami in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2010, 12:58 -
dvd with menu with music
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 8th Jan 2010, 21:58 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Removing scenes from DVD while keeping original Menu?
By saini in forum Newbie / General discussionsReplies: 1Last Post: 25th Oct 2007, 22:42
8) I really appreciate this so thank you very much
I also have
