How much performance would i see if i update my graphics card from a 256 8600GTS to a 768MB 8800GTX OC.
p.s.
I have a pci express slot
My PC Is Custom Built... Look At Computer Details Above...
Performance with what? If you are into gaming you will probably see better or faster graphics. For everything else, you'll see the same picture on your monitor as you always have seen.
The graphics card only deals with displaying the image on your monitor, nothing else. Changing from an already fairly high spec card to an even higher spec card will succeed in making your wallet thinner, but it is unlikely you would notice any other difference. -
Though with that said even though its a relatively minor generation change the fact that the ram is so much higher will allow you to up the resolution and detail considerably. I'd say if you are trully into needing the absolute best for pc gaming then go ahead and do it if its within your budget.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Likely be unnoticable, unless you are one of the few people that play games at very high resolutions (over 1280x1024).
check out testing at a site like tomshardwareGoogle is your Friend
Need another graphics card already!
By A Traveller in forum ComputerReplies: 15Last Post: 26th Sep 2011, 16:07 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
Graphics card question
By eclipse95 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2009, 08:54 -
need a new graphics card..
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 28th Dec 2007, 01:50 -
What sort of Graphics Card/Capture Card to get
By Dr_trout in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 15:19
