Microsoft DV driver for Sony DV appears to capture in half DV resolution (360x240), even though the captured AVI file reports video properties of 720x480. The reason I noticed this is when I play the AVI file with Windows Media Player and set the Zoom to 100%, the movie frame appears only 360x240. The frame size becomes 720x480 only after I set the Zoom to 200%. Can anybody explain why? Here is my setup.
OS: Windows XP
laptop: Compaq Presario 1700 (933MHz PIII, 256MB)
1394 firwire: built-in
cam: Sony D8 TRV330
hard drive: passes the data rate test of Pinnacle Studio (about 15Mbps).
capture software: Windows Move Maker, Pinnacle Studio 7 SE, MGI VideoWave III SE
Huey Lee
:o Ya, mine does this too. The only way I have captured at 720x480 with the MS Dv, is to use windows movie maker, which sucks!
-Chris JL -
Your problem is not in MS CODEC. It is in Media Player's setting, in playing DV AVI files.
Your AVI has no problems at all. DV AVI is fixed, and there really is nothing to change in there for capturing (or should I say transferring) to your HD.
You should be able to change this in Properties in Media player. Unfortunately, I don't remember the exact steps, so I'd suggest you play around. -
Try loading the DV AVI file into VDub or TMPGEnc. They should report the true resolution of the file.
Sony DVCAM and AV/C tuner driver problem
By Sean_ve99 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Nov 2009, 19:34 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Half D1 resolution problem
By sebrame in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 10:18 -
Sony VGN-A130 Driver needed.
By TBoneit in forum ComputerReplies: 6Last Post: 30th Jun 2008, 11:44 -
320x240 avi's to Half-D1 Resolution
By louv68 in forum Video ConversionReplies: 10Last Post: 15th Aug 2007, 09:12
