I know there are like a million messages posted on this topic. But I want something simple and I can't seem to find it through the threads. (Call me impatient)
Anyway I have AVI movies about the size of 624 x 352. And I simply would like to burn it on a DVD to watch on my DVD player without the show being stretched as what happened when I tried a simple burning software.
Is there anything that coverts the AVIS to DVD files(vob, iso) or anything related without changing the file in any way?
Is there any software that can adjust the AVIS size so that it burns correctly on a DVD?
I would like to avoid so many steps to getting the AVI to DVD such as having to go through VirtualDUB, or other softwares.
Many thanks in advance.
Convertxtodvd, FAVC, the Film machine... many others.
All in one DVD Converters
If you want to learn the steps to do it manually CLICK HEREDonadagohvi (Cherokee for "Until we meet again") -
If you have a typical video off the net, (Xvid, 700MB), you won't find much easier than ConvertX. It also does very good conversions, including PAL to NTSC.
If you have a higher quality video source, you might look into the individual tools for editing, encoding, authoring, and burning. For that I use MPEG-VCR, TMPGEnc encoder, TMPGEnc DVD Author, ImgBurn. Lots of others available, depending on how much you want to spend and how much time you want to spend learning to use them. There are also freeware alternatives for all of this that do a similar job. But they have a steeper learning curve.
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 09:36 -
help burning AVI file onto DVD
By dunce in forum Authoring (DVD)Replies: 31Last Post: 10th Feb 2010, 19:40 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 06:40 -
Burning several avi files to a DVD
By shashgo in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2008, 09:23 -
Burning a .avi file to DVD!!!
By guitarparth in forum Newbie / General discussionsReplies: 9Last Post: 16th Nov 2007, 13:08
