Can anyone help me out. I'm needing a DVD burning software. I need one that when creating menus it will let you have an image on say the left side and have a list of the episode titles in text that you click on to view each episode? I'm using Nero now - not sure what version - and all it will let me do is have text under the thumbnail images for each video and I can't stand the thumbnails covering up the backgrounds. Thanks.
TDA2 (or 3) will within a second or two generate a menu with everything editable (text buttons, image and text obejcts from file, motion or still background/audio from file etc.). If you have DVD folders created in any other software and just want a better menu you can import that project by titles keeping chapter information, then select a template close to menu type you want (without thumbnails, I also hate them) and edit it using your graphic files. Then you test + output project to DVD folders and burn it with Nero (there's also an option for burning from the program).
If you just have MPEG2 DVD files you can completely author your DVD without learning much (using wizard). That's one of the most time-saving but flexible enough solutions. -
GUIForDVDAuthor is free and can easily do this, however you would have to encode the videos to DVD spec yourself. HCEnc is a good option for this.
Read my blog here.
Good and free DVD Menu Software
By PDX Ghost Hunter in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2010, 08:48 -
Which authoring software has good motion wedding menus?
By sterankin in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2010, 04:21 -
Need FREE DVD Authoring Software (Which Authors VOBs & Allows Menus Etc)?
By larrytxeast in forum Authoring (DVD)Replies: 15Last Post: 26th Jul 2010, 13:07 -
Help with what software is good for menus and chapters
By shashgo in forum Authoring (DVD)Replies: 9Last Post: 3rd Jan 2009, 17:09 -
GOOD Mac DVD Author software?
By jnaylor in forum MacReplies: 14Last Post: 15th Sep 2008, 13:03
