    Feb 2007
    hi, i want to compress some movies that i have as .iso files, to save some space, im not going to burn them for a while, which format should i use, 7z, zip, or rar
    thanks
  2. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    I used rar because its smaller.....
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  3. ISO images of movie DVDs will not compress by much.
    Dec 2004
    Australia
    Usually 7z compresses the most, followed by rar with zip in last. As said though I wouldn't expect much of a gain and compressing a ~4GB file could take some time.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You are talking small degrees of compression in comparison to each other. If you must store ISOs, buy a big external drive. Either that, or burn them to disc or re-encode using a better video compression method.
    Read my blog here.
    Feb 2007
    ok thanks guys, how do you know what types of files will compress better than others?
