Ok ill try make this sound like sense
i have a movie with bad video and english audio
i have the SAME movie with perfect video but russian audio
is it possible to put the english audio onto the russian one? please help if you could thanks guys.
Yes. First of all of is the time length identical for both movies? If not you'll have to work out synch issues which might make it too much work to be worth while.
You can use virtualdub or virtualdubmod (mod if its an mpeg file, virtualdub only reads avi). You would go to streams and delete the original audio and then import the new audio.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
hey what do you mean import the new audio, both of the audio's are like in the .avi o_0
You would have to go to file-save wav or extract the stream and get the file as a seperate sound file. Then you go to where you saved the one you want to use and put that in your new compilation.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
