Results 1 to 11 of 11
Thread: h.264 in AVI
  1. #1
    Member
    Jul 2007
    Australia
    Posts
    6
    h.264 in AVI
    Is it possible to make an AVI using H.264 or x.264 codec?
    Member
    Dec 2004
    Triptonia
    Posts
    1,177
    Yes,
    http://deaththesheep.uni.cc/
    Or if you've already got avc you can use avc2avi on a raw h264 clip.
    gl
    Member
    Jul 2007
    Australia
    Posts
    6
    Sorry couldnt find anything on the url...
    MOV with H.264 is easy but
    cant find anything about AVI with H.264
    any ideas?
    Member
    Dec 2004
    Triptonia
    Posts
    1,177
    look again.
    download installer. install.
    use vdubmod. select x264 compressor, configure, encode.
    avc in avi.
    take existing h264 clip, extract to raw,
    use avc2avi
    avc in avi
    gl
    Member
    Jul 2007
    Australia
    Posts
    6
    true sorry bout that....but I am on a MAC...anyother ideas?
    Thanks for your help
    Member j4gg3rr's Avatar
    Nov 2005
    Australia
    Posts
    125
    MeGUI
    EDIT:
    MAC! MAC!! Run XP on a virtual machine
    Member
    Dec 2004
    Australia
    Posts
    4,200
    Why would you want to put AVC in an avi file?
    avc2avi should run fine under OS X and you can use mp4box or similar to extract the video from mov/mp4.
    The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    Posts
    4,290
    You can do this easily with SUPER encoder.
    Also, you can do this with virtualdub and the unofficiall vfm x264 codec.
    MeGUI also does it.
    VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Posts
    4,756
    Except the OP is using a Mac, so those aren't really an option (at least, he ruled them out above).
    I wonder if ffmpegx or VisualHub could do it.
    Member
    Dec 2004
    Australia
    Posts
    4,200
    Well Super is just a front-end for various OS cli encoders, most of which should run fine on a Mac. mencoder or ffmpeg can encode via x264 to an avi, in fact for mencoder it is the default output format.
    Jan 2006
    Posts
    4,756
    True.
    I just happen to encounter a lot of people on both the Windows and Mac side who'd rather not have much to do with CLI/console programs (me being an exception), so I tend to default to suggesting GUI applications first. Have to do something about that.
    (That, and I was actually supposed to get some sleep for a change, this morning, not answer forum posts. Never happened. )
  1. Sound and video do not sync up when I convert avi to h.264 x 264.
    By toddlava1 in forum ffmpegX general discussion
    Last Post: 8th Mar 2012, 02:15
  2. Lossless Conversion from AVI H.264 to MP4 H.264
    By kenchen in forum Video Conversion
    Last Post: 22nd Oct 2010, 14:04
  3. Replies: 6
    Last Post: 15th Sep 2007, 10:11
  4. h.264 to avi
    By backlash in forum Video Conversion
    Last Post: 19th Aug 2007, 04:27
  5. Replies: 4
    Last Post: 18th Jul 2007, 09:25
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
