I have an avi with an srt file that I have converted to a mpeg for dvd. I want to import it to dvd author. When I do this the file loads fine and so does the srt file but has all the tags with the font and color. I just want the words not the tags. How do I fix this.![]()
Use subtitle workshop to search and replace the tags that you want to omit.
I don't know of any way to do it any faster or easier. -
Do i have to edit each line manually?Theres only 800 n sumthin.I'm new at the subtitle thing
You only have to edit each instance of the tag or phrase you want replaced if you replace all in the search and replace.
If I replace the italics tag, I have to seperately replace the beginning and ending tag. There could be 200 instances of each. Copy and past the tag into the find or search box and leave the replace box empty.
It depends on how many different phrases you want to replace. It won't take long at all.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
Second SRT File Not Recognized on Philips DVD Player
By gonwk in forum SubtitleReplies: 7Last Post: 22nd Dec 2010, 17:13 -
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 11:45 -
Burn .VOB File with .SRT to DVD+R DL (HELP!)
By holdenmcclure in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 01:47 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58
