I've checked the latest version of AVI2Clipboard and it is 2.18, which is not compatible with Windows Vista (I'm on 64 bit). When right-clicking on avi file on Windows XP it will have an option for AVI2Clipboard, but it doesn't appear on vista.
So if this program doesn't work... I will have to find something else. I need a program that will tell me the information about the AVI file, giving off detailed information like AVI2Clipboard does. I would like to have the information in format that I can copy-paste it, or take a screenshot of it. Any tools that is nearly as good as AVI2Clipboard or could do something like that would be great![]()
Or better, if there's a way to make AVI2Clipboard compatible with windows vista, it would be perfect! Right now the program can be installed and uninstalled, it just doesn't appear on the menu when I right-click on the avi files.
Thank you very much in advance,
Nattawat
You can try MediaInfo and GSpot. I use GSpot - it works fine under Vista, but I can't guarantee whether or not anything will work under the 64-bit version.
Have you tried uninstalling AVI2Clipboard, then installing it by right-clicking on the setup file and choosing to run it as the admin?If cameras add ten pounds, why would people want to eat them?
Are any of these programs Vista compatible?
By magicfingers in forum DVD RippingReplies: 12Last Post: 7th Aug 2008, 20:04 -
Is DVD-RB compatible with Win Vista???
By Eternal7331 in forum DVD RippingReplies: 3Last Post: 11th Oct 2007, 01:31 -
Daemon Tools for Vista
By mysts in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2007, 20:13 -
Vista compatible?
By Anonymous4374945 in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 11:55 -
Vista compatible program?
By smudger2468 in forum Video ConversionReplies: 4Last Post: 31st May 2007, 17:09
