Why does it tell me that the file has been created but when I check the file - it's zero KB in size?
I'm trying to create FLV files, but I have also tried to convert to other file types - but it always creates an empty file? It creates the file in about 1 second?
Can anyone help me with this???
Sonic
Results 1 to 16 of 16
The encoding failed. Please post the log to let us help you find out what went wrong and how to fix that.
Here's the log...
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Tue Jul 3 17:57:50 BST 2007
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/sonic/Desktop/panto.mov':
Duration: 00:02:26.6, start: 0.000000, bitrate: 837 kb/s
Stream #0.0(eng): Audio: adpcm_ima_qt, 44100 Hz, stereo
Stream #0.1(eng), 14.98 fps(r): Video: h263, yuv420p, 320x230
Codec type mismatch for mapping #0.0 -> #0.0
Audio is listed before video, which is inverted from what the encoding engine wants. Check the Invert mapping checkbox in the Audio tab to tell ffmpegX how to deal with that. Then try encoding again. That should fix things.Originally Posted by aquasonic
a similar thing happened to me while converting flv to mp4. here's the log:
Fri Jul 6 08:34:52 CDT 2007
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 30.00 (30/1)
Input #0, flv, from '/Users/alexsemaca/Desktop/dunk.flv':
Duration: 00:00:08.3, bitrate: N/A
Stream #0.0: Audio: mp3, 22050 Hz, mono
Stream #0.1, 30.00 fps(r): Video: flv, yuv420p, 320x240
I am having the same problem and tried with and without the Invert Mapping checked with the same results, my file is converted in a about a second and the file size is 0k.
Any suggestions to this dilemna?
Here is the log:
Mon Sep 3 14:32:54 EDT 2007
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/brennan/Desktop/GroundControls_Part1.mov':
Duration: 00:03:32.8, start: 0.000000, bitrate: 252 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo
Stream #0.2(eng), 15.00 fps(r): Video: h264, yuv420p, 832x464
OR
Mon Sep 3 14:44:09 EDT 2007
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/brennan/Desktop/Part1.mov':
Codec type mismatch for mapping #0.1 -> #0.0
The double audio stream is causing trouble here. If you have QuickTime Pro, then try deleting one audio stream, save as a new copy, then convert.Originally Posted by bsmity
Not sure why I am unable to access the video file, I have changed it from the long name to a shorter name just in case. I still am unable to create my file for my ipod.
I have other files working just fine, I copied all my music videos over to my ipod just fine. but sitll no 300.Encoding started on Tue Sep 4 17:04:23 MDT 2007
x264 [info]: using SAR=1000/1001
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
mp4 [info]: initial delay 0 (scale 24000)
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
ERROR: Could not open movie: /Users/auiotour/Movies/300 Title 1 (Ch1 - Ch30)/300.m2v
Encoding audio..
x264 [info]: final ratefactor: 52.05
usage: movtoway -o output.wav movie.mov
Ok I had the same problem as the first post and I followed the instruction to select "invert mapping" in the audio tab. Doing so created a flash movie rather than an empty file but it plays back at about 2 frames per second no matter how the video settings are set. I took the exact same file and reversed the order of the audio and video tracks in Quicktime pro by extracting, deleting and then pasting the extracted audio back. I then deselected the "invert mapping" button and it made a movie that played just fine.
Is there an error with the "invert mapping" function that is leading to this? I was going from MPEG 4 to FLV and reducing the size from 640X480 to 320X240 and the frame rate to 15 Fps from 30.
Here is what the Bad encode log looked like:
This is what the good encode log said:Encoding started on Thu Sep 6 14:28:17 MST 2007
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Media Drive 3/001 No Spirit Left Behind/Masters/Sequence 11 a.mov':
Duration: 00:00:28.3, start: 0.000000, bitrate: 7860 kb/s
Stream #0.0(eng): Audio: pcm_s16be, 44100 Hz, stereo, 1411 kb/s
Stream #0.1(eng), 29.97 fps(r): Video: mpeg4, yuv420p, 640x480
Output #0, flv, to '/Volumes/Media Drive 3/001 No Spirit Left Behind/Masters/Sequence 11.flv':
Stream #0.0, 15.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, pass 1, 300 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
video:249kB audio:194kB global headers:0kB muxing overhead 76.931297%
bench: utime=11.330s
Stream #0.0, 15.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, pass 2, 300 kb/s
Stream mapping:
bench: utime=6.040s
video:252kB audio:194kB global headers:0kB muxing overhead 75.996975%
Encoding completed on Thu Sep 6 14:29:07 MST 2007
Encoding started on Thu Sep 6 14:18:44 MST 2007
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Media Drive 3/001 No Spirit Left Behind/Masters/Sequence 11.mov':
Duration: 00:00:28.3, start: 0.000000, bitrate: 2870 kb/s
Stream #0.0(eng), 29.97 fps(r): Video: h264, yuv420p, 640x480
Stream #0.1(eng): Audio: pcm_s16be, 44100 Hz, stereo, 1411 kb/s
Output #0, flv, to '/Volumes/Media Drive 3/001 No Spirit Left Behind/Masters/Sequence 11.mov.ff.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 384x288, q=2-15, pass 1, 300 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:1106kB audio:194kB global headers:0kB muxing overhead 1.719312%
bench: utime=11.240s
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 384x288, q=2-15, pass 2, 300 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
bench: utime=16.510s
video:1041kB audio:194kB global headers:0kB muxing overhead 1.810359%
Encoding completed on Thu Sep 6 14:19:48 MST 2007
I don't think so: the stream mapping itself is working fine. There are some other odd thing here, tho'.Originally Posted by Plisko
Originally Posted by PliskoYour good encode has different source bitrate, different source video codec, different output framerate, different output video size. You changed more than the stream order, it looks like a re-encode, which makes comparison more difficult ("apples and oranges," as they say). That alone doesn't account for the 4x more video data, tho'. Quite odd.Originally Posted by Plisko
Try Decode with QT in the Option tab, to see if that helps getting better/smoother playing output.
If route #1 (default settings) won't bring you desired results, then try route #2 (change some setting, like Decode with QT).
Wow. . I tried to re-encode the same exact thing with the same settings as the other file to try repeating the error. I can't believe it was that far off. I may have accidentally used the wrong file or grabbed the wrong log. I'll see if I can repeat this again in the morning using the same exact file.
I've tried the invert mapping solution above and no luck.. still zero K files. I'm trying to convert an MP4 to flv. Log below... The last line mentions a codec mismatch... any help would be greatly appreciated. Pixelgeeek
Wed Sep 12 13:01:30 PDT 2007
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/admin/Desktop/iStock_000003717826Small We.mp4':
Duration: 00:00:10.5, start: 0.000000, bitrate: 7706 kb/s
Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 320x240
Output #0, flv, to '/Users/admin/Desktop/iStock_000003717826Small We.mp4.ff.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 320x240, q=2-9, 200 kb/s
Stream #0.1: Audio: aac, 22050 Hz, stereo, 56 kb/s
Stream mapping:
[aac @ 0x54340c]codec not compatible with flv
Could not write header for output file #0 (incorrect codec parameters ?)
bench: utime=0.036s
Encoding completed on Wed Sep 12 13:01:31 PDT 2007
ffmpegX to PSP conversion creates unreadable, Zero KB files
By Peter Sarkisian in forum ffmpegX general discussionReplies: 5Last Post: 15th Feb 2010, 11:06 -
Empty vob files?
By Ndre in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2009, 14:57 -
ffmpeg produces empty files
By letter17 in forum ffmpegX general discussionReplies: 10Last Post: 3rd Feb 2009, 15:16 -
why does sub2divx creates very small video files
By amtemp in forum SubtitleReplies: 1Last Post: 21st Sep 2008, 05:16 -
Creating empty files
By jr1 in forum ffmpegX general discussionReplies: 1Last Post: 29th May 2007, 12:58
