I have a project that requires me to videotape propietary software on a computers screen. I need to show how the software works. You will see the mouse select items and see screens changing, etc...What is the best way to videotape this? Aiming a camera at a computer screen and hitting record is obviously not the way to go. So if I am on location, what would I need and do to get the cleanest image of what is on the screen?
Thanks,
SR
your approach sure seems like the hard to way do that. There are software packages out there that will do exactly what you are wanting to do. The cost is not very over the top and might be worth the time to investigate. CamStudio and Quick Screen Recorder are two that come to mind but I am sure there are others.
Windows media encoder
Camstudio (grab there screen caps codec)
Screen recorder from zd soft : http://www.zdsoft.com/
If working with programs that use video windows , you may need to cut back video acceleration , or the areas containing video will be black .
By Krissu in forum Newbie / General discussionsReplies: 5Last Post: 16th Apr 2011, 14:45 -
How to take BluRay screen captures - FREE
By SOHkat in forum Software PlayingReplies: 14Last Post: 11th Feb 2011, 16:56 -
Screen Captures?
By newsphotog in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 16:35 -
How do i stream cable tv into my computer screen?
By cooldog87 in forum DVB / IPTVReplies: 6Last Post: 13th Dec 2007, 00:15 -
My computer keeps rebooting before the logon screen.
By SE14man in forum ComputerReplies: 4Last Post: 8th Sep 2007, 15:21
