ntsc or pal which is better in quality???
and can someone tell me if i can create a vcd that have
352x288
1150k
29.97 frame/s
224kbit audio layer 2
1 more question is the higher in number the frame/s is the better the quality???
thanks
jacknjt,
You seem to be able to type well, too bad you can't read very well.
1 - Search before posting, just like the message says before you post.
2 - Look in the little blue box in the left hand corner and read each topic.
3 - If you're color blind, the box says "WHAT IS" and lists the topics of VCD, SVCD, X(S)VCD and DVDRW.
Then, if there are still questions, you can ask them. Each of your questions and more will have a direct answer in just a few pages.
I must have read information for weeks before even posting a question. So, if you are new to help forums in general, I'm sorry if I came off strong. You should always gather some information before asking questions. It helps others help you faster and helps you understand what you are asking by looking for more specific help.
But...Give a man a fish and he has food for a day, teach him how to fish and he has food for a lifetime. -
The best standard is PAL not NTSC Film because higher Resolution is better quality and better quality need more space so the framerate must be lower. The best standard for America is NTSC Film. Here are the Standards:
America
NTSC
Audio: 224 kbps
Video: 1150 kbps, 352 x 240, 29.97 fps.
NTSC Film
Audio: 224 kbps
Video: 1150 kbps, 352 x 240, 23.976 fps.
Europe, South - Africa & Japan
PAL
Audio: 224 kbps
Video: 1150 kbps, 352 x 288, 25 fps.
Bye bye,
yysie -
My DVD player can play PAL VCDs, but I still feel more comfortable making NTSC VCDs because I live in USA and I want to be able to play these discs on all my friends' players.
But it's hard to ignore the evidence: 288 is more vertical resolution than 240. However, it is an odd factor when reducing an NTSC captured source ___x480. But 25 fps is closer to 24 fps (the film rate) and 30 fps would just be telecined anyways (or deinterlaced).
Darryl -
For VCDs, NTSC-FILM definitely looks better than both PAL and NTSC settings.
Although PAL has a higher framesize, that isn't the be all and end all of quality. NTSC-FILM has effectively 20% more bits per frame than both PAL and NTSC and at the bitrate hungry levels of VCD, it makes a hell of a difference.
Whether PAL VCD looks better than NTSC VCD is contentious. In my experience, they look about the same.
Regards.Michael Tam
w: Morsels of Evidence
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
60fps versus 50fps? PAL or NTSC in AVCHD?? need advice!
By ftitus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th Nov 2010, 07:11 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
