Please tell me, what codec do I need to install. I have number of Avi videos that when I play them, i only get the audio but not the video, I installed the
avi codec pack and Xvid 1.1.2 and NVIDIA drivers. and this files still don't show. I mean there are others that do play but those still do not, help needed please.
Codec packs = bad news.
The first place to start with any video playback problems is G-Spot. It will tell you what codecs are being used, and if you have them installed.
You can also use VLC for playback of most codecs without the need to install the codecs themselves. It travels with decoders for most formats built-in.
If you have problems reading the G-spot info, post a screenshot here and someone will help out.Read my blog here.
thank you, but i use Avicodec instead of Gspot, it is the same as Gspot. it tells me the codecs of the video and it says it's all suppourted.
here is the info:
File: 787 MB (827 MB), duration: 0:15:32, type: MPG, 1 audio stream(s), quality: 75 %
Video : 777 MB, 7000 Kbps, 25.0 fps, 720*576 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 49 MB, 448 Kbps, 48000 Hz, 2 channels, 0x2000 = AC3 DVM [0x80], Supported
I really hate VLC and don't want to use it, this videos played normally before on my computer, i just reinstalled windows and now i need to set up all the codecs i had before again, so there for sure was something, that made it play before. -
It's MPEG2, not AVI.
He's a liar and a murderer, and I say that with all due respect. -
type: MPG, so it isn't an avi. Also for avi not just any MPEG-2 decoder will do.
MKV Audio + AVI Video to avi using ffmpeg?
By kwanbis in forum Video ConversionReplies: 9Last Post: 15th Apr 2012, 20:45 -
hi8 to avi Vs digital to avi capture using S-video connection?
By jaybird in forum Capturing and VCRReplies: 3Last Post: 29th Apr 2009, 22:48 -
[MOV => AVI] Need help, why the result AVI video cannot be played?
By ohboy888 in forum Video ConversionReplies: 16Last Post: 2nd Mar 2009, 13:51 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 19:16 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
