Every time I add an asset the programme shuts down, I am using build 2.5.2738 and running vista ultimate, the error I get is svcd has stopped working, windows is checking for a solution to the problem, a problem caused the programme to stop working correctly. Windows will close the programme and notify you if a solution is available, and its in a box that has 2 buttons, debug and close programme. I press the debug thing and nothing happens. I cant find any log files to post. I'm not very techy and i use svcd because its so easy and produces good results, please help if you can. Incidentally convertx2dvd and windows dvd maker are also closing down,any ideas please ?
Can you try the latest version (Version 2.5.2800) and make sure you follow the advise here: https://forum.videohelp.com/topic324278.html#1672927
I downloaded the new one, installed it and registered it with no problem. I am now going to try a project, keep fingers crossed....lol, I will report back
Thanks, ChrissyBoy, it's working fine now
Computer shuts down
By shaolin2006 in forum ComputerReplies: 16Last Post: 18th Nov 2011, 23:15 -
PC Auto shuts down
By anfield7 in forum ComputerReplies: 2Last Post: 18th Feb 2010, 04:02 -
PC unexpectedly shuts down
By maccool111 in forum ComputerReplies: 23Last Post: 7th Nov 2007, 09:54 -
MIRc shuts down
By DuBsTaR in forum ComputerReplies: 2Last Post: 22nd Oct 2007, 14:23 -
Monitor shuts down
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 1st Oct 2007, 19:00
