Hi, can anyone recommend a DVR in the $100-150 range? No hard drive is necessary, but I need a tv tuner, and the recorded discs need to play on other machines. I'd prefer a brand that will not be disappearing soon.
thanks,
brad
You did not mention what kind of TV tuner and if you are in the US. ATSC tuners are now appearing as required by law in the US but it also limits the choices available.
Doesn't DVR stand for Digital Video Recorder? And AFAIK, all DVRs come with an HDD?
Are you looking for a DVD Recorder instead? -
Models disappear with regularity as cost reductions continue.
I have both a Lite-On LW-5005 (discontinuted) and an Insignia (Best-Buy rebadged LG) DVD-R1.
The LG is a more solid unit with a better tuner. The Lite-On has firmware updates, the Insignia/LG has not.
I find either maker preferable to RCA or Magnavox in the price segment you have identified. -
oh-- I'm in the US, so it's NTSC. With regard to ATSC, I'm fine with getting an older--but recent-- model via ebay, etc, as well.
thx,
brad
Originally Posted by trhouse -
Is the Lite-on model you mention the same as the LVW-5005?
http://us.liteonit.com/us/index.php?option=com_content&task=view&id=29&Itemid=119
Originally Posted by oldandinthe way
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Recommend a budget desktop
By SIZZ in forum ComputerReplies: 4Last Post: 8th Feb 2011, 12:08 -
Capturing DVR to Hard drive
By frikadil in forum Capturing and VCRReplies: 5Last Post: 18th Nov 2009, 13:48 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58 -
Hard Drive DVR's Availability?
By giannid in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th May 2007, 13:00
