I have a mpg video that's 8:30 mins, the movie info from Quicktime Pro
says Format is MPEG1 Muxed 320 x 240
Data size 84.8 MB
Data Rate 1399.11 kbits/sec
File size 320 x 240
I want to reduce the size to no larger than 34 MB
I want to set up my public folder on my iDisk (i only have a 60 day trial)
so i want to put it thru the paces and see if it's worth it or just buy space on
another server
I have tried several methods. the best i could do is use MPEG Streamclip and reduced it to a 288 x 204 mpv with a Data rate of 622 kbits/sec.
The result the file size is 37:42 MB
I could reduce the file more but file size will be to small
What should i use to keep it as close to the original size, and yes i know i will lose some quality, it will only be played on the computer.
sknoxx
If you transcode to h.264, you will certainly achieve your desired filesize while maintaining reasonable image quality and dimensions. A bitrate of 300kb/s would be fine for a 320x240 image size. MPEG Streamclip is the best tool for this nowadays with with the x264 version of h.264 installed. If you're committed to mpeg1, then ffmpegX does a pretty good job of encoding very low bitrate mpeg files, although the quality doesn't match h.264.
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
Reducing the size of an avi file with Vegas 9.0
By solarblast in forum Video ConversionReplies: 10Last Post: 3rd Sep 2011, 23:01 -
Reducing video file size
By black5 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jul 2010, 18:09 -
Reducing the file size of digital pictures
By hardy in forum Off topicReplies: 25Last Post: 10th Mar 2010, 08:59 -
Limitingand reducing out file size
By TJF in forum Video ConversionReplies: 6Last Post: 7th Feb 2010, 10:25 -
reducing video file size
By srckaimal in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2008, 21:51
