Okay I have been playing around with the DV avi renders that was recommended, but I keep getting a weird 'shimmy' in the output videos. The pics I used are of a high resolution, so I thought that might cause the weird look to them whenever I put them into my project, but I am not sure. Are there any formats that would give me a good enough format for projection, but rid me of this compression issue?
What software are you using? How are you presenting the result to the projector? Downsizing requires low pass filtering to avoid harmonics.Originally Posted by VTSwordfish2002
I'm just using Vegas Movie Studio, the render is NTSC DV avi format at its standard settings. I will be passing it to the projector via s-video
In Vegas there is a render setting called Quality. Setting it to Best can help avoid some of these issues when resizing stills. Movie Studio may have the same setting. If the images have sharp horizontal edges or thin horizontal lines then you can get interlace flicker along the edges. Applying a very small gaussian blur, or a vertical directional blur can also help in these cases.
Read my blog here.
Is Sony Vegas Movie Studio HD Platinum 10 a good editing software?
By vid83 in forum EditingReplies: 8Last Post: 4th Feb 2011, 08:02 -
Sony Vegas Movie Studio editing question
By viking5 in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2010, 05:01 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 01:41 -
Sony Vegas Movie Studio 8 Memory Issues
By jrockford1974 in forum EditingReplies: 3Last Post: 10th Jul 2008, 15:39 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 16:14
