I recently bought component cords for my dvd player, and when i plugged them in, the image was there, but it had a blue tinge to it. i know that its not my tv, because it is ok with everything else. and my dvd player does have component jacks, so i know it can handle it.
any suggestions?
Are you sure each cable is plugged into the proper sockets? Or all the connectors are making proper contact?
And welcome to our forums.
For analog component, the green connector carries the Y monochrome detail.
If you pull off the Pr (red) connector, the picture goes green.
If you pull off the Pb (blue) connector, the picture goes pinkish purple. -
I hate to be Mr Obvious, but did you setup the DVD player to output over component? I seem to recall having a similar issue with my player when it was setup to output on S-Video, switching the output (in the video setup menu) to component solved the problem.
Google is your Friend -
im sure that all the connections are making full contact, and i am pretty sure that the tv's component sockets are all working. i tried connecting the dvd player to both of the tv's component connections, and i get the same thing. i am starting to think that the red connector on the dvd player is faulty. i can switch the cables around on the dvd player, and the picture comes out in different shades. (red blue or green) and ive noticed that the red socket never works. so i think that might be the problem.
but Krispy Kritter has a good idea too. but i dont think that my dvd player has a setup menu.
if it did, how would i get to it? -
Look for a "Setup" or "Menu" button on your remote. You might well have a bad connector on the Pr (red) channel, but that's usually easy to fix, just touch up the solder joint.
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Blueish screen with media player and tv tuner
By Alvito in forum Software PlayingReplies: 1Last Post: 20th Jan 2009, 03:08 -
Problems with screen blank using component video switches
By digitalsamurai in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2008, 17:51 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
