Is there any tool that does the above? I have a video that plays too fast. GSpot says the framerate is 29.997, and I think maybe the person who encoded it should have used 24 fps. I've tried playback with FFDshow and CoreAVC and both play the clip back too fast, so it seems to point to an encoding problem.
It's MP4. I tried MPEG4 Modifier, but it didn't work. It only works with MPEG4 Layer 2 files.
It only works for MPEG-4 Part 2 video streams stored in an avi container and doesn't change framerates anyway, so that would be three strikes.
Use Yamb/mp4box.
Encoding SD video with H.264 to be 100% Blu-ray compliant.
By PuzZLeR in forum User guidesReplies: 14Last Post: 19th Oct 2015, 18:12 -
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 05:17 -
Change IDX/SUB Framerate
By r9800pro in forum SubtitleReplies: 8Last Post: 15th May 2010, 23:46 -
Choppy video with h.264 encoding from Matroska
By gabbahh in forum ffmpegX general discussionReplies: 2Last Post: 2nd Jul 2009, 22:05 -
What happens if AVI video is 4:3 and you change to 16:9 during encoding?
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2007, 06:48
