  1. Hi! I was just wondering is it possible to burn my DVD Videos in the DVD-ROM(UDF)format? Will they still play on a regular dvd player? Thanks! Sorry, I almost forgot I am using the Newest Version of Nero!
    Apr 2004
    Miskatonic U
    Use imgburn instead. Much better than Nero. Burn to DVD+R and use bitsetting and your player will see it as DVD-ROM.
    Read my blog here.
  3. I use DVD-R, also I have had terrible luck with ImgBurn. Lots of playback issues like skipping and such! Thanks though!
    Apr 2004
    Miskatonic U
    Skipping is usually poor media or media compatibility with your burner. You cannot make DVD-R look like DVD-ROM.
    Read my blog here.
  5. I have the problem with 3-4 Different Burners and the media is Tayo Yuden(Sp?). I was just wondering if it is possible to have them recognized in a DVD Player, cuz it gives me the option in Nero. Thanks for all the help!
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD uses UDF by default - usually UDF and ISO. Your DVD player will recognise them if they are burned as DVD Video. Nero has a DVD Video template to do just this. However they won't look like DVD-ROM, they will look like DVD-R. If you want the player to think it is a DVD-ROM then you have to use a technique called BitSetting, which is only available on DVD+R discs.
    Read my blog here.
  7. I dont want the player to think anything. I was just wondering if I could use the DVD-ROM UDF setting and they would still work!
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you are going to use Nero, use the DVD Video template - that's what it is there for.
    Read my blog here.
